Posted · Feature request
Loving cura. Not sure if mentioned somewhere already. Is it possible to develop an adaptive layer table for custom settings for each desired layer height.
And is it possible to develop concentric rib infill. Just like how you would add ribs to a part to make it stronger. Since its concentric it conforms to the shape of the part and one can determine if it should be on corners, vertical/horizontal or both, width, height, density, shape, inside or outside the part, connected to outer/inner wall etc.
Thanks,
Carl
