Z base to default position
bartoloman
Posted · Z base to default position
What happens if you turn the Z screw by hand? Maybe the z stepper isn't attached?
Maybe you need to show a very short video. Maybe print something of dimensions 1cm by 1cm by .3mm and just show the end of the video.
