Thank you for your feedback. I printed the benchy with 200°, 60° bed and 60mm/s with Innofil PLA. I will try print another one with 20 or 30mm/s and another one with 190° or maybe even 180°.
200° is basically ok, but give it a try with 190°, if you see under extrusion it was too cold.
Smithy 1,134
I would say it is not so bad, some minor issues but overall a good print.
Try to print a little bit cooler and slower. Not sure, but when looking at the surface I would say you print too hot. Then I see some ringing, which should be better when printing slower.
