Thanks for the fast response....
- Am i able to pause the UM3e from the front screen live (or through Cura while live), i assume i can then change the filament and restart the print if i see the spool getting low.
- Also i assume it will feedback to Cura the live monitor over a wired LAN connection?
- Do they come pre-built or are they kit form?
Smithy 1,135
Hi
I cannot say how much weight the plate can handle, but 0.5kg should be more than save, even if you print 2 at the same time.
The UM3 has no filament sensor, only the S5 has it. So if filament runs out on the UM3 the printer continues the print job without extruding. You can only add a manual pause at a certain height, to switch the spool.
