Even if you find a material, it is not going to pop up automatically, if printed flat. On the contrary: even if you would pull it up manually, it will tend to snap back into the flat shape as when printed, because that is how the molecules were solidified.
You would have to print it in the upright position, and then manually push it down to make it pop up again from itself (if the material is flexible enough to survive this).
You could do this by designing a custom support structure that does not consume too much support material.
johnse 30
You could print a layer or two of PVA (water soluble) or Breakaway between the pieces. They're not "non-stick" but breakaway has lower layer adhesion and PVA will dissolve.
