Dual filament holder
Posted · Dual filament holder
As i got the dual kit to actually work with newest cura.
im wondering if someone have solved the "2 spools on one spool holder"
When i got my ultimaker, the spool holder was to thick for these 32mm ish, spools.. And its post hot end v2, and pre extruder update.
And when i was calibriating, i had to keep an eye on the spool no2, as the retraction can knock the spool over, or make it run towards the floor.
How i got mine to work:
Used snowugrounch how to, had to enable the hot bed in his version of the marlin code.
Uploaded it.
and it started working, though the X/Y offset for the second nozzle was WAY off in the settings. (like X23, mine is now Y22,7 PS: this is not my final setting, as its not fully calibriated, but this will get you in the ballpark.)
Though it might be an glitch, as i tryed to print while the printer was just updated, with no off time to settle the electronics.
So, anyone have solved the arised problem with having 2 spools hanging on the back?
