Hi gr5.
Just open up a new Cura and flick the prime tower on and off. You will see the shaded area increase / decrease around the edge of the build plate. I can think of no reason why this should be, so to resolved this, I have gone into machine settings and increased the working size of the build plate to 225mm in the "Y" direction. Seems to be working fine.
Something else I have noticed with the latest cura, 4.2.1. I can no longer have the first layer of support at 100% density, this has just stopped working.... however there are many settings in Cura I just don't understand so perhaps I am doing something wrong?
What I really need is a setting so the first layer of print on top of support material is speed variable, or a setting so one can change the speed for individual layers. Sometimes a print messes up because I don't get to manually slow it down when vulnerable details are printed.
Cheers,
Paul.
gr5 1,872
Can you show a photo of what your part looks like and the location of the prime tower (show screen shot of cura is what I mean) and also in cura do a "file" "save" and post the 3mf file here. The 3mf file will include ALL your settings, your printer settings, your part to print, the orientation of the part... everything. So other's on this list can duplicate.
I'm going away for 2 days so someone else will have to answer this.
