How to get a smooth bezel print job?
splicer
Posted · How to get a smooth bezel print job?
I have drawn a simple model with a 2 inch bezel in both Sketchup and Blender.
Both models produce similar results after printing with Cura 4.2.1
The "steps" or "segments" of the bezel are very pronounced and I want them to be very smooth.
After trying this in 2 different modeling softwares I am thinking my answer is in Cura.
I print daily with the Ender 3 and have determined the printer itself is not the issue.
Attached is .STL from sketchup so you can see what I am printing. Also attached is an actual print job of the terrible results.
Is there some settings in Cura to help smooth this out?
Thanks
2 Inch SU.stl
    Assuming you're printing it as the STL...if you want it smooth. The only thing I could think of is to use quite small layer height. But since we are talking about FDM... I guess 0.05 will be the limtation?
    You could try rotating it 90 degrees.The problem is that printers aren't simultaneous 3d so the Z will always be in small steps because they can't move all three axis at the same time. I work with cnc's and  printer is what we refer to at 21/2D.
    • Like 3
    This worked perfectly! A very smooth print job. Thank you for the brilliant suggestion 🙂
