[UMO+\E3DV6] Extruder calibration lead to underextrusion
Posted
· [UMO+\E3DV6] Extruder calibration lead to underextrusion
What layer thickness are you printing this with? From what I have read elsewhere, using a single wall to calibrate flow rate is not a good measure.
To check for proper calibration, print a calibration cube with infill and measure the resulting cube.
AFAIK, to check for proper flow and bonding with a single wall, you want to focus on the finish of the surface and layer bond strength of a spiralized cylinder.
johnse 31
Catlord 17
Cube print (and better the calibration cross ) allow to set up the step/mm.
also the calibration cross allow you to see if there in an horizontal expansion parameter you can play with.
I'm taking note about the spiralysed cylinder, do you have any reference about it please ?
