Cura 4.2.1 will not save profile
kmorris1077
Posted · Cura 4.2.1 will not save profile
I'm seeing a particularly  frustrating problem on Cura 4.2.1 on Windows 10.  When I make changes to an existing profile and then use the "Create profile from current settings" command, my settings are lost.
Steps to repro:
1) Choose the Fast 0.2 mm profile
2) Change the Printing Temperature (I choose 205c).
3) Select ""Create profile from current settings/overrides"
4) Name the profile, "Foo"
Expected
All changed settings are maintained in the print settings panel under the new Foo profile
Actual
The foo profile changes to what appears to be the Fine profile (layer height is 0.1mm) and all changed settings are lost.
This is such a mainstream feature that I have to think my Cura files are corrupted in some way, but I don't know enough about the Cura file structure to know what I should attach here for diagnosis.
TIA,
Kevin
    • 4 weeks later...
    Posted (edited) · Cura 4.2.1 will not save profile
    I have the same problem. I am also using v. 4.2.1 (Windows 10) but the problem was the same in older version (see https://github.com/Ultimaker/Cura/issues/4162)
    I discovered that when I save a profile it is saved all right in C:\Users\My Name\AppData\Roaming\cura\4.2\quality_changes but when I open Cura it is read just in  C:\Users\My Name\AppData\Roaming\cura\4.2\quality
    I solved myself manually editing profiles  in files in \quality folder but is not the right solution.
    I include my configuration files:
    cura.zip
    Edited by RobyRob
