Hello Smithy!
Thank you for your answer.
I read about this topic before and then proceeded to manually level the build plate so that the bed screws are tightened as much as possible. Unfortunately, the tool from your link can't be used on the S5, because the carrier is not open to the sides as the one in the pictures. It's curved upwards like in the front also on the sides.
Anyways, our build plate height looks exactly like on the "how it should be" picture in your link. But what I noticed when controlling this a moment ago is that the glass plate is closer to the carrier on the right than on the left side. Manual leveling turns out fine, but the difference is still there, though it is only like 0.2 mm, but it's there.
Smithy 1,141
It is not normal, AL works for fine on my S5 without any issues.
But I have one idea, check if the height of your bed is round about 14mm. This was often a problem/fix with the UM3 and I guess this could also be a problem with your S5.
Here some more details and pictures what I mean:
https://ultimakernasupport.zendesk.com/hc/en-us/articles/115005705806-Why-Isn-t-My-Active-Leveling-Working-
