@johnse Yes it is correct, Creality Ender 3. I did a reinstall, printed with default settings and everything worked. I changes some settings, it went back to underextrusion. Tried going back to default and now that is under extruding where it was not before. It's like changing any of the settings changes the material diameter to 2.85 but I can't see it or change it 😞
- 2 months later...
I'm using an ultimaker 2 with a stock machine profile with cura 4.4 freshly installed and freshly updated firmware on the machine. My machine is also massively under extruding. Its like that either cura or the firmware thinks that i have an ultimaker 2+ machine even though I have selected ultimaker 2 in cura as my machine. There are some other strange problems in my setup also including that it is printing every other line for the bottom.
1
Did you follow a guide for extrusion calibration, set a new extrusion on Ender 3 and forgot to add the Cura Gcode fix for the extrusion?
Edited by mkrmec
johnse 31
Have you checked the machine definition? What printer do you have?
