jhertzberg 19
Regarding using a rotating wire in a tube (bowden cable) to get mechanical energy to the head, chopmeister tried it and had no success. See http://umforum.ultimaker.com/index.php?/topic/2544-small-steppermotor-for-direct-extruder/?hl=hysteresis#entry18161. I have been playing around with the idea of constraining a loop of beaded chain under tension in a pair of PFTE bowden tubes with beaded chain pulleys wed to gears, within a housing, at either end. I previously built an articulated arm, attached to the head and the back of the frame, with a pair of pulleys bringing power to the head from a motor on the frame, but still don't have that working satisfactorily.
gr5 1,873
I like the thought. This idea might trigger another. You should post a link to this current thread into this thread:
http://umforum.ultimaker.com/index.php?/topic/3174-ultimaker-rd-we-want-your-ideas/?p=23569
Someone else also talked about getting mechanical energy to the head - in their case using a rotating wire in a tube like for a speedometer cable in an automobile. This is similar to pneumatic energy transfer. In either case you need very good control of movement of the filament.
