Thanks for the quick reply.
I have not tried a cura connect reset yet, didn't think that would affect the bed level.
When I do a manual level I follow the onscreen instructions. I do not have a z offset plug in.
If I try and do a manual bed level, the print is a good 4 to 5 mm off the bed and that's right after I did a new level.
When I do an auto bed level I need to adjust all the screws by about a quarter turn to pull the bed away. If I don't, the nozzle is so close that nothing at all comes out of the nozzle, but the prime blob is working so I know the extruder works.
I print with a skirt, I rarely use a brim unless I have to for a large print. I don't tend to have issues with adhesion.
I don't really know what I'm looking at when I look at the raw GCODE but here is the gcode for one of the most recent prints that I had to manually adjust the bed for.
;START_OF_HEADER
;HEADER_VERSION:0.1
;FLAVOR:Griffin
;GENERATOR.NAME:Cura_SteamEngine
;GENERATOR.VERSION:4.4.1
;GENERATOR.BUILD_DATE:2019-12-23
;TARGET_MACHINE.NAME:Ultimaker 3 Extended
;EXTRUDER_TRAIN.0.INITIAL_TEMPERATURE:220
;EXTRUDER_TRAIN.0.MATERIAL.VOLUME_USED:25627
;EXTRUDER_TRAIN.0.MATERIAL.GUID:506c9f0d-e3aa-4bd4-b2d2-23e2425b1aa9
;EXTRUDER_TRAIN.0.NOZZLE.DIAMETER:0.4
;EXTRUDER_TRAIN.0.NOZZLE.NAME:AA 0.4
;BUILD_PLATE.TYPE:glass
;BUILD_PLATE.INITIAL_TEMPERATURE:60
;PRINT.TIME:38301
;PRINT.GROUPS:1
;PRINT.SIZE.MIN.X:9
;PRINT.SIZE.MIN.Y:6
;PRINT.SIZE.MIN.Z:0.1
;PRINT.SIZE.MAX.X:170.206
;PRINT.SIZE.MAX.Y:161.075
;PRINT.SIZE.MAX.Z:4.5
;END_OF_HEADER
;Generated with Cura_SteamEngine 4.4.1
T0
M82 ;absolute extrusion mode
G92 E0
M109 S220
G0 F15000 X9 Y6 Z2
G280
G1 F2700 E-5.5
;LAYER_COUNT:56
;LAYER:0
M107
M204 S313
M205 X10 Y10
G0 F4333.3 X77.088 Y71.633 Z0.1
;TYPE:SKIRT
G1 F1800 E0
G1 F780 X78.057 Y70.618 E0.01056
G1 X78.152 Y70.523 E0.01157
G1 X79.165 Y69.546 E0.02216
G1 X79.206 Y69.507 E0.02258
G1 X79.657 Y69.087 E0.02722
G1 X79.761 Y68.994 E0.02827
G1 X81.055 Y67.889 E0.04107
G1 X81.067 Y67.879 E0.04119
I have checked all the wires in the back of the print head and the red wire for the bed level is working. When I run a diagnostic on the bed level sensor it says it's working good.
gr5 2,167
When you do the manual leveling, do you turn the knob on the front of the printer (not one of the 3 leveling screws) when you level the rear spot? And do you turn the front leveling screws for the front two locations? By the way, unless you change the 3 screws a *lot* you can just skip over the whole "1mm" steps.
Are you sure you don't have a Z offset plugin? Can you post the first chunk of gcode? About 50 lines - up until where it sets Z for the bottom layer (typically 0.27mm) and then starts printing the skirt or brim.
