Posted · Pause at Height, Cura 4.2.1 = problems
Hi Ultimaker/Cura people,
I have problems with my print since I have updated Cura. Before, I was using print at height with 7mm, and it worked fine. Now, it is not working anymore if I am using pause at height with mm, but it is only working with pause at height with layer. This is weird. So I have switch to the layer system, and ask to pause at layer 48, and it is working in the sense that it is making a pause. But, when you start the print again, it can print anything because the nozzle is too high, too far from the print.
Do you have a solution please?
Thanks
