ultimaker 2+ sd card reader, part number.
kenjo
Posted · ultimaker 2+ sd card reader, part number.
So my printer has problems detecting the sdcard when inserted. I removed the IO card to get access to the card slot and it works fine when I insert the card and press on the top of the reader. Once the card is detected I no longer need to press and things works.
Now I wanted to replace the part as I suspect springs/pins has been damaged so it no longer connect to the pads on the card. But what is the part number ???
I found something like it here DM1AA-SF-PEJ
https://www.mouser.se/ProductDetail/Hirose-Connector/DM1AA-SF-PEJ21?qs=sGAEpiMZZMuJakaoiLiBpnXBVL%2BdeeUj9Z%2BiD5E3UFQ%3D
Is that the correct one ??
        • 8 replies
