Support Z distance problem
arianna
Posted · Support Z distance problem
I'm trying to print this model which needs support in the upper part, the supports should be based on the model itself but even setting Z distance to 0 a significant gap remains between the model and the supports, not allowing me to print correctly... any idea what the problem could be?
    Hi and welcome
    I think you also need to adjust support X/Y value due to the slope.
    My first example Z is set to zero and X/Y default Cura calculated value
    Adjusting X/Y value will close the gap.
    (I wouldnt go to zero gap though, usually difficult to remove support then)
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
