Fascinating. I envy you and your molten metals!
FYI many people print ABS without a heated bed. There are 2 issues - shrinking, and shrinking. The first issue is that it's harder to get things to stick to the bed (due to shrinking). Some people have solved this with "ABS GLUE" (google it) and printing on glass. Also adding a brim helps and printing as hollow as possible helps (infill pulls at the sides lifting the corners off the build plate).
The second issue is shrinking - if you print something like an inverted cone - something with overhangs - even very mild overhangs, the shrinking effect which pulls in on the sides of the part as you print - now it rotates the edge and mostly lifts the edges of the part until the print head hits these edges and either damages the part or knocks it off the print bed. Even a mere 45 degree outward angle is a major major problem with ABS. Pretty much unprintable without heated chamber.
But if you are printing things with vertical sides (like typical mechanical parts) (rounded corners on top are not a problem - it's outward leaning sides). And if you are printing smaller objects (under 2 inches across) then you might be fine with ABS. With ABS glue and 1/4" (thick!) glass plate you might even be able to use the full 8 inches of bed space.
IRobertI 521
Maybe PLA 90 from Orbi-tech could work?
