So to create an all inclusive settings glob, name the project as something like "ACME PLA 1.75", then save a 3mf without a model loaded. Since I'm always using the GUI that should work. Thank you.
Do you have a link to all the macros that are for the machine settings?
gr5 1,514
They are called profiles. You can save profiles. I have a different method that seems to work better as I have heard all manner of horror stories related to profiles but have NEVER had a problem with my own method.
First of all when I think everything is sliced right I click on the text in the bottom left corner and name what I want to call the project. This is of course optional but saves you time as you will be creating 2 files not one. Then in the bottom right I do "save to disk" which creates either a gcode file, or ufp, or what have you depending on the printer. Then I do menu item "file" "save" which creates the 3mf file. Also known as a "project" file (not a profile).
The 3mf file is amazing - it saves what profile you used (e.g. "fine") and it saves all your overrides. It also saves your model (or models) and where you positioned the model and how you scaled it and rotated it. It also saves your machine settings! So if you send the 3mf file to someone else they will get all that plus your machine settings! It's just very very useful and the file is barely larger than the STL file(s) in it.
I have upgrades cura many times and never had a problem reading in an old stl file. The profiles on the other hand - don't always work when you upgrade (I hear - never tried it myself).
Once you have loaded a saved profile or a 3mf file you can see what settings were overridden. Make sure you are in advanced settings mode and where it has the name of the profile (e.g. "fine 0.1mm") there is a star. Click that star and there is a popup. This part isn't perfect but I find it very very useful. Look at the columns of settings and see which changed but more importantly click on the "extruder 1" tab and you can see most of the settings changes (from the basic profile) there.
