The XY calibration adapts for the different core diameters by adjusting the amount of material extruded and adjusts the brim pattern too.
@rebekah_harper When you say there are problems, can you elaborate?
Looking at the code it seems to always print at 0.3mm which for a 0.25 nozzle better would be lowered to 0.2mm.
Smithy 806
If you have different cores you have to calibrate each combination. From the serial or GUID number of the core, the printer knows if you have a new uncalibrated core or not. I am not sure if you have to recalibrate the cores if you swap the positions, but I guess yes you have to do it.
