Looks water tight to me, if you mean holes.
I pulled it off a different character using Blender. I didn't model the shield myself
Even then it seems a bit ridiculous to mark the entire 2 sides red if there is just a hole somewhere?
Could also be a problem or failure during the export to the STL file and not water tight doesn't mean you always see the problem. A single polygon which is missing could be enough.
Try to repair the STL file here:
https://service.netfabb.com/login.php
You have to create an account, but the service is free.
I managed to fix it in Blender (there were no holes). The 2 sides of the shield were isolated planes, which isnt allowed for some reason.
I connected those 2 circles into a cylinder and now it prints fine
In fact from the pictures you could've easily guessed this instead of 'check for holes' 🙂
Edited by wouter931 hour ago, wouter93 said:The 2 sides of the shield were isolated planes, which isnt allowed for some reason.
The reason is that the mesh needs to clearly delineate what is inside vs outside the solid. Isolated planes do not define a solid.
If you are interested in more details, you can google “boundary representation” or “BREP”.
glad you were able to fix it.
Smithy 1,146
Your model is probably not watertight and therefore the slicing fails and Cura shows you the red areas.
Have you designed the model yourself and if yes, with which software?
