I see it, thank you very much.
I poked around and it doesn't seem to follow the same resources\meshes structure, how do I go about pointing my settings to display my platform mesh?
Thanks again.
Edit: I've managed to create a working def.json under resources/definition and got my platform mesh working. Still curious if it's possible to do it with a custom printer profile. Thanks!
Edited by chilicoke
Smithy 1,134
The json file is located in the user configuration folder and not in the application folder.
You can find the path via Cura Help menu -> Show Configuration Folder. There should be a definition subfolder.
All user modified settings are saved in this configuration folder and not in the generic one.
