Thank you for your reply.
How do I make sure that those definitions are correct on my Ultimaker 3?
I am using CURA 4.3.0
Drawings from Fusion 360.
I set the printer as Ultimaker 3 in the window top left on the CURA slicer window.
At first, i would check that you've actually selected "Ultimaker 3" and not "...S3".
Although i guess it would give you (at least) a warning if you try to print it on the wrong printer model.
And you can check the extruder offsets in machine settings.
Nozzle offset x/y should be zero for "Extruder 1" and 18mm on x for "Extruder 2".
If everything is correct on the software side, it may be that the lift switch calibration on the printer is wrong and the printhead collides with the bracket or the side panel while switching nozzles?
Edited by tinkergnome
tinkergnome 918
I'm just guessing, which slicer do you use and which machine definition?
Be aware that the extruder offset for the UM3 and the S5 is not the same.
