Thank you for the quick reply! I have been using a regular glue stick, so that may be the issue. I have the nozzle height pretty close, so I am not sure it is the distance.
Can I ask what you recommend cleaning the glass with after printing? We use a scraper to lift the prints - and they come up easily, but there is some residue on the glass. Maybe I should try heating the glassbed and cleaning?
Smithy 1,146
Your problem, I think, is adhesion to the glass bed.
For this you should adjust the distance between nozzle and print bed again and make the distance slightly smaller. Furthermore the glass should be clean and free of grease. Additionally I use a UHU stick which I roughly apply to the glass and then spread with a damp cloth to a thin film. Then the object holds firmly on the plate and when the printing bed has cooled down, it can be easily loosened.
