DivingDuck 105
Look for plugin "Printer settings" by fieldOfView at Marketplace. It will give you access to your hidden printer settings in Cura. Compare the values with your firmware setup. Guess, this will give you an explanation why there are so huge differences.
Best way to get rid of this profile mess is building your own set of printer profiles (at least for me).
Be careful and change only values you know about for not damage the profiles.
marcottt 0
hi, i have same printer and same issue.... time is totally wrong. last was 85 min predicted and more than 140 min real....
also there is not a profile and every time i need to rebuild because EVERY upgrade cura tell there is something wrong with profile...
