I understand that leveling would be the go to. I have leveled beds hundreds of times (on my old printer and now a dozen on this one). I thought the bed may be different than my old printer so I tried leveling it high. Of course nothing stuck. Then I leveled it low and it had the usual problems I leveled it as it should be, with the right amount of friction on the leveling card.
I am getting a perfect first layer.
Do you use the glue even with PLA? I can give that a go later, and I haven't done the wet cloth method. I won't get to it today, so hopefully some other tips will come through that I can test.
Oh also, I am really careful to remove the test pla that it spits out at the beginning. That ruined one of my early prints.
Smithy 1,141
In 99% of the cases it is because the printing bed is not correctly leved. The distance between nozzle and glass is too high. If you calibrate with the calibration card or a sheet of paper, then you should feel a good friction of the nozzle already when you move the sheet. Better too much than too little.
I also use a glue stick, which I apply to the glass and spread with a wet cloth. This gives me a very thin layer, which is completely sufficient.
