its a duet3d based corexy machine.
tinkergnome 926
1 hour ago, mangy_dog said:its a duet3d based corexy machine.
In this case i would rather create appropriate tool change files for RepRapFirmware - to make the parking method completely independent from any slicer or its settings.
IMHO this is the correct place to handle those tasks. Do it once for the machine and you'll never need to think about it again.
And it's very well documented:
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_files
tinkergnome 926
I'm no Cura expert, but there are start- and end-scripts for each extruder in the machine settings. Those are executed on each switch to a different extruder. You can use any gcode command in these scripts that is supported by your printer.
For Ultimaker printers this task is handled by the firmware (no script needed), so i assume you use a printer definition that is contributed by a third party? Or is it a self-construction?
