Dim3nsioneer 557
It takes indeed pretty long to finish the abort procedure. A 'skip cooldown' procedure (which does not end up in the wrong position of the filament) would be appreciated. When you abort a print you usually don't want to wait for minutes until you can start over again.
Edited by Dim3nsioneer-
1
Smithy 1,141
I had the same experience but actually it is working, just the screens are different.
Before there was a circle with a progress bar during the cool down.
Now there is just the X but the printer still cools down. After a few minutes you get the button to remove the print. Depending of the print and bed temperature this can take a while.
Same behavior when a print is finished, just with a checkmark.
Personally I preferred the previous screens, the new ones are confusing but still working. So I don't think your bed heater was still on, actually it was slowly cooling down.
