Posted (edited) · Stuck in cooldown (latest S5 frimware)
I just updared my S5 firmware and the first print ended and just sat there in the cooldown phase with the print head a short way above the print
@CarloK please help
I selected skip cooldown, then the next print went haywire !, it dragged the nozzle accorss the bed after the level procedure and then the bed just dropped all the way to the bottom and failed !!!!, the software effectuvly crashed, never seen this before
any ideas, can i roll back firmware ?
Also i updated my Mac to Cataylina, but cant see how this would affect the slice and the end of the print ?
Edited by Link
    also, when its sitting in the cooldown phase, print core 2 heats up and then cools down !!!, someting is very wrong
    then if i wait around 5mins the print head homes and the print finishes
    Edited by Link
    Posted · Stuck in cooldown (latest S5 frimware)
    I think they have I bigger problem. Today I got the air manager. The Air Manager was recognized with the new firmware but not configured. When you do I got an unspecified Error (E36)
    The downgrade of the firmware will work again, but with no air manager.....
    i am not sure you can downgrade the FW, is this possible ?
    1 minute ago, fbrc8-erin said:
    You can downgrade firmware if you have an older version saved on a USB stick.
    i dont have the older version, is there somewhere to get those (incase it goes bad again)
    Ultimaker.com/firmware
    Edited by lrodriguez
    Your printer will also display this after certain conditions.
    But just go into the update menu and it will be there.
    since yesterday there is a "new" Firmware. And as you can can read in this forum the new one is the old one. Ultimaker makes a roll back to 5.2.11
    Not sure I follow, I wasn't prompted to do a update. I just reinstalled whatever UM gave me when I said install latest. Are you saying this is back to a older version ?
    This makes more sense now, I was on 5.4 and must have flashed 2.11 back, will check the version numbers later. Not sure why my printer didn't prompt me to roll back. 5.4 is badly Brocken. It dragged the print nozzle accross the bed and dropped the bed at high speed into the end stop !!!, That should have never been released !, Just lucky my printer isn't damaged !!
    @CarloK please help
    With the new firmware I found that even if you select to skip cooldown,  you can not "confirm removal" of the print and move on with life untill the bed has cooled down to 59 deg.   This is a pain if you are printing with CPE and the bed temp is 110deg and the you about the print on the first layer and want to restart the print right away.  With previous firmware versions it was faster to powerdown and power up the printer to retain bed heat, but with the new firmware this too is not possible.  When the printer restarts, it still wants to cooldown.
    Did this ever get fixed? I still have this issue where skip cooldown doesn't skip the cooldown and it costs me a lot of time every day and I use almost exclusively PETG.
