Flashforge Dreamer Profile?
Carla_Birch
Posted · Flashforge Dreamer Profile?
I been trying for a bit now to get a working profile so i can use Cura for my Flashforge Dreamer printer but i'm not having much luck at all, does anyone happen to have a working printer profile they could share or give help in setting one up?
Here is the code that flashprint puts out when you slice with that: https://pastebin.com/HmkDRv3T
    • 3 months later...
    hi there!
    i am currently working on a flashforge dreamer3d profile and i made it work perfectly fine with one extruder.
    unfortunately cura adds a line with T0 to the gcode file when you activate the second extruder which makes the file unusable..
    but as long as you stay with one extruder everything works fine..  i'm on it 😉
    https://github.com/valueerrorx/Flashforge-Dreamer3d-Cura-Definitions
    • 3 weeks later...
    On 1/24/2020 at 11:39 AM, xapient said:
    hi there!
    Is the code for the left or right extruder? I personally use the left one for PLA as it works better with being closer to the cooling duct.
        • 2 replies
