Cura Configuration Folder ? Wher is this situated!
You find it here: ~/Library/Application Support/cura/4.3
When you delete the whole 4.3 directory or everything lower than this number, you will start with a fresh copy. You can also try to just rename the latest (4.3) folder to something else and delete the previous versions.
Sorry but this didn't help.
I removed the 4.3 Config directory but no changes at all. A white screen appears nothing more.
I attached the log for Cura just after installation, perhaps some one can help.
Kind regards
Willi
Carla_Birch 115
It’s working fine for me also in Catalina, maybe remove Cura fully and reinstall it.
So I solved the Problem just a couple of minutes ago.
Problem was an USB-Unit where cura tries to access to as a Printer, but it Isn't a printer. I removed all USB Units attached and which I didn't need for working with cura and reallised that the Docking station for my Sportswatch was the reason to prevent Cura from a correct starting.
Now I have to check why, for hell, cura tries to read USB-ports.
But thanks to you all.
It was enabled, now I disabled it and attached the USB device causing my Problem.
What should I say, everything is fine now.
Thanks for this hint.
Smithy 1,111
Cura 4.3 runs fine for me on Catalina, so it must be something with your installation.
You can try to delete your Cura configuration folder, that you can start over with a fresh installation. But be aware that you will loose all your settings.
