UMs5 - Print Core Loaded/Stuck but printer doesn't register it
LB1
Posted · UMs5 - Print Core Loaded/Stuck but printer doesn't register it
Help! I must have done something wrong when changing print cores from AA 0.4 to AA 0.8...the printer accepted the new print core but didn't start my print. Now the print core is STUCK but the UMs5 says no print core is loaded. When I try to "load" the print core, it just tells me to insert until it clicks, but since the print core is already inserted it won't read it and I cannot get the printer to think there's somethin g there so I can then unload. I am also unable to remove the bowden tube to pull out the material to then remove the print core. I also do not know how to clean the back of the print core since it's already loaded. What do I do?
    Posted (edited) · UMs5 - Print Core Loaded/Stuck but printer doesn't register it
    I have also had the "ghost print core" a couple of times. Wit me it course after a print is done.
    Some times I have had luck in just turning of the printer at the back, and when it powered on again the core was registered.
    If that doesn't help you can, unclamp the bowden at the back, release the fillemet tensioner and pull a bit of fillment throw, then you can cut the fillement and pull of the bowen.
    carefully try and "cold pull" the fillemet out and if not possible cut the fillement right between the cors metal part and bottom of the print head.
    73014928_563973944340567_934893086167793664_n.thumb.jpg.ddb90a660efb89ffb1f4de519d49c45a.jpg.a0e0e2294c98c0e3b160af287fbd9151.jpg
    It is prity hard to cut without damaging the print head, so if in doubt I would check if it's covered by the warranty.
    Why do my posts always double post pictures??
    Edited by NBull
    @NBull thank you for the help! After turning off/on, Ultimaker magically registered the print core again. I was able to change the print core, manually remove the filament & cut off the damaged parts (the feeder ground it down on one end and it had gotten pretty messed up on the other). I re-loaded material and got my print going in no time. Thanks again!
        • 10 replies
