@Smithy, your reply is correct and I think fairly comprehensive in regards to the Support Blocker function in Cura, but I think the OP speaks to a real problem: for something this simple and straightforward, there should never be any reason for a user to have to resort to forums to figure it out.
In my experience, Ultimaker documentation has been decent, but there is always room for improvement. If there are ways we can make the user experience of the Cura software better or more intuitive—especially for tools that are front and center and will likely be explored by any curious user—we should definitely strive for that. Settings hidden in the preferences pane need it a little less so, but there is nothing which could not be benefitted by adequate documentation; things that are obvious to experienced 3D printers are not always so for the beginner.
Smithy 1,111
It is easy to use the support blocker function.
You select your model where you want to block the support.
Click on the support blocker icon in the left menu or press E
Then click somewhere on your model where you want to place the support blocker cube.
The cube acts like a model, so you can move or scale it to fit your needs.
And the area which is covered by the cube will not have any support after slicing.
