Chemical resistance chart for PLA
SiddharthTilala
Posted · Chemical resistance chart for PLA
Dear Friends,
I am looking online for the chemical resistance chart for PLA. But for some reason, I found not even a single decent information on this domain. If i would search for Chemical resistance chart for other filament material, i was able track down some pdf for it but not for PLA. Does any one have any source or literature for PLA?
Thank You,
Best Regards,
Siddharth Tilala
    You will not find a generic chart for PLA because each manufacturer uses different components zu mix the PLA. So best you check the website of the manufacture to get the needed data sheets.
    i.e. Colorfabb PLA
    https://colorfabb.com/files/FKUR/TD_BIO-FLEX_V_135001_en.pdf
    https://colorfabb.com/files/FKUR/MSDS_BIO-FLEX_V_135001_en.pdf
        • 2 replies
