11 hours ago, ahoeben said:Have you tried lowering the "minimum support area" setting to 0?
Thank you for the suggestion. Unfortunately, it does not work. This setting causes the support to be a single line up to the finger tip. My printer is not able to print a single line straight up since the bed moves.
I am going to use the "Custom Supports" add-in that was recommended by a YouTuber called "Chep". Wish me luck!
ahoeben 1,657
