Posted
· Ultimaker 3 Extended Print Material Gunking Up
When you get a sizzle sound during printing PVA, it means that your PVA spool has absorbed too much moisture from the air. PVA is very sensitive and should always stored in a dry place. Never leave your PVA spool on the printer.
You can try another spool of PVA or dry your spool on the heated print bed over night.
Before you print you should also clean your nozzle with some Atomic pulls.
1
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Smithy 1,141
