well if thats the case then shouldnt i be able to tinker around marlin to add E1 and E2 if necessary as part of the gcode that relays command to both extruders? I feel like this already exists in marlin and that i just need to understand how its laid out to get it to work.
just so you know, I am making my own printer so a manufacturer help/tip is not an option.
Edited by slashban
tinkergnome 926
Well, at first this needs a printer that supports it ("duplication mode" or whatever it is called by the manufacturer). This applies to both, the hardware and the firmware of the printer.
Given such a printer - it usually comes with a slicing software that can produce gcode for this mode.
There's no "standard" for gcode (AFAIK) - it always depends on the implementation of the manufacturer. So - you have to take a look at the gcode file that is generated by the provided software - or you can simply ask the particular manufacturer.
