Where to find a list of possible {config_values}
3Dsuco
Posted (edited) · Where to find a list of possible {config_values}
Hi!
First, sorry but I don't know how to call these objects between brackets.
I would like to find a list of the possible options to be added in the start gcode.
I am actually using the following start code at Cura 4.3 to show the used config during slice:
;Print speed:   {print_speed} THIS DOESN'T SHOWS ANYTHING AT THE GCODE.
;Retraction amount:  {retraction_amount}
;Infill density :  {infill_sparse_density}
;Infill pattern :  {infill_pattern}
;Wall thickness :  {wall_thickness}
;Layer height   :  {layer_height}
M140 S{material_bed_temperature_layer_0} ;Set bed temp and continue
M109 S{material_print_temperature_layer_0} ;Set hotend temp and wait
M190 S{material_bed_temperature_layer_0} ;Set bed temp and wait
I have found the previous while googleing but the print speed for example doesn't work. I also would like to add the accel and jerk config to the gcode file.
So, is there any list of the {} options to be used?
Many thanks in advance
Edited by 3Dsuco
        • 10 replies
