In my experience the filename will get reset when you do New Project under the File menu but not if you just delete an object and load a new one. But I haven't had the filename persist after quitting cura and restarting it. So until someone gives a better answer try using New Project before loading a new file and see if that works for you.
S-Line Firmware 8.3.0 was released Nov. 20th on the "Latest" firmware branch.
This update is for...
All UltiMaker S series
New features
Temperature status. During print preparation, the temperatures of the print cores and build plate will be shown on the display. This gives a better indication of the progress and remaining wait time. Save log files in paused state. It is now possible to save the printer's log files to USB if the currently active print job is paused. Previously, the Dump logs to USB option was only enabled if the printer was in idle state. Confirm print removal via Digital Factory. If the printer is connected to the Digital Factory, it is now possible to confirm the removal of a previous print job via the Digital Factory interface. This is useful in situations where the build plate is clear, but the operator forgot to select Confirm removal on the printer’s display. Visit this page for more information about this feature.
LindsayPatten 1
rac8006 0
Thanks for the response. I should have known this when I opened the next file and it showed up in addition to the original file.
