2
here's a part of an older thread, mentioning your problem:
On 7/18/2019 at 5:13 PM, hughwyeth said:
BINGO
You're a genius dude, thanks so much for your post. I'm 99% sure this is it (or at least part of the problem)- when i originally saw the arm had this dip in it I thought it must be part of the design but on removing it, it's clearly been worn out.
I take it I need to contact a local reseller to source this part? Is there a more durable alternative version out there?
On 7/18/2019 at 8:31 PM, Enigma_M4 said:Hi,
the part-numbers are 1967 (the worn-out half on the photo) and 1968.
One also realy useful solution would be this:
http://www.youmagine.com/designs/ultimaker-3-extruder-lever-mod
Works pretty well for me.
Regards
Regards
ultiarjan 1,223
All parts used to be for sale separatly, but I also noticed the "spare parts book" only shows the full assembly.
As you can see here I bought my first feeder completely from parts....
Here's the partnumbers of the arm, I would say just try to order it from your reseller...
