By steps do you mean the current? Set to 1000mA per the BondTech specs. Also tried bumping to 1200mA (max rating for that motor) with no change.
No not the current, I mean the e-steps which should be at 492.?? Or something like that. You find the correct value in the Bondtech manual or here in the forum.
The UM2 uses a quite lower value 28? And this could explain why you need to dramatically increase the flow.
You cannot set this value with the stock Firmware but you can set it via gcode. The Tinkerfw has a menu option for that in the motion menu.
Check the Bondtech site, there are detailed instructions how to configure the e-steps.
I am quite sure this is your problem.
I guess you have set it in the past but lost the value with a firmware upgrade or factory reset.
The correct value for the e-steps and the Bondtech QR feeder is 492.45
If you don't want to use the Tinkergnome FW, you can set the value with the following GCODEs:
M92 E492.45
M500
With M500 you save the value to the eeprom, so you don't have to put the first line in every gcode.
1
You nailed it! I had a feeling I was overthinking it and overlooking something obvious.
Must have looked back at that manual 10 times and somehow didn't see the note about e-Steps.
Thanks for your help!
I'm glad it was the reason and it's working again.
Smithy 1,141
Have you set the steps for the QR feeder to the correct value?
