Thanks for the advice about the fan connector. I will check it.
Just to be sure I understand what you are saying, are you referring to the procedure described in https://ultimaker.com/en/resources/50882-replace-the-axial-fan?
The core has less than 500 hrs on it.
gr5 2,024
The front fan is a very serious issue and could explain everything. Remove the rear 2 screws on the print head and the rear cover will pop off easily. Push down firmly (with the head in a corner so you don't bend the rods) on the connector in there and see if that fixes the fan.
Also how many hours are on that core. The teflon may have gotten old if it's say 2000 hours or more. Under 500 hours I'd say no way.
