Cura infill is ignoring small holes
cdman12
Posted · Cura infill is ignoring small holes
Hi all, after one of the recent updates, infill in Cura is ignoring small holes (1.5mm and below). The infill goes straight through these holes, and is not adding the extra infill wall to them like bigger holes. Is there a setting I can adjust to change that? Thanks!
    What I see on your screen shot is that even bigger holes do not have appropriate walls...
    So I would rather guess there is a problem with your STL file. Did you allready try to make a new STL with other settings?
    Thanks for the file, it definitely looks like a bug to me, I will investigate...
    Hello @cdman12, it is indeed a bug which I have fixed and hopefully the fix will make it into a future release.
    Awesome, thanks for the quick response!
        • 6 replies
