Isn't there a way to send the GUUID of say "PolyBrand Grey" to the printer before hand, so that it recognizes it?
I've tried the steps you linked above, but Cura still responds with "switch unknown to PolyBrand Grey" or whatever, when i try to start the job.
I realize the firmware link is a great idea incase you switch filaments and forget to update your Cura job, but this is frustrating me.
Smithy 1,131
The best way is to setup you materials correctly in Cura. When you add a custom material, you should duplicate a generic profile which the material is based on. Then the GUUID of the material is the same as the generic material you select when loading and then no override message comes up.
I wrote some time ago a deeper description of that topic:
