here's some inspiration for you ....
Thanks, just checked the price of the CC core !, over £320 !, ouch, that's expensive!, I am sure it used to be less than this ?!
On 11/3/2019 at 6:47 PM, Link said:Thanks, just checked the price of the CC core !, over £320 !, ouch, that's expensive!, I am sure it used to be less than this ?!
it was always just below 300 euro i think. Probably the effect of the pound not doing to well.....
ok, so have tried ColorFabb metal fill, Steel, Copper and Bronze on my S5 using the CC core
In terms of printing it prints fine, not quite as easy as straight PLA, prints pretty much like a wood-fill, so if you have a profile for that you are pretty much there. Retractions are a challenge, but still doable, just the usual light deposits where the material oozes slightly, but again nothing major
the biggest issues is getting the advertised finish, the Copper for example is pretty much just orange, pla with Copper in it, which is fine, one of the recommended methods to make it much more copper-like is to sand then polish, i have tried this and it still looks like orange(ish) pla with a slight shine. According the Colorfabb wire wool then polish is the way to go, so i am going to try that. But at the moment the part doesn't look like i had hoped.
What does surprise is the weight of the part, its really heavy, feels like metal in terms of mass.... i just need to get the finish and then I would recommend. Not tried the finishing on the steel yet, i assume that will need the same finishing method once i perfect it...
Wire wool coming today
Smithy 1,114
Not tried yet myself, but S5 with CC Red core is fine to print such materials.
Let us know when you have results!
