Reduce “support horizontal expansion” to zero.
7 hours ago, johnse said:Reduce “support horizontal expansion” to zero.
This may also help. But I didn't mention it because for 90% of prints you want this at the default 3mm for very good reasons. I guess the quick summary is that pva sticks to the glass bed well but not to pla very well (it sticks, just not well). So you want the pva portion to have a path all the way to the glass. "support horizontal expansion" often (usually? sometimes?) fixes this issue and makes a disaster print into an excellent print. Depending on your model.
In this kind of situation where the support is fully inside the external walls, the horizontal expansion serves no purpose and puts thin walls of support on the outside.
These thin pieces almost invariably break off and contaminate the PLA portions.
gr5 2,094
Make sure "support x/y distance" is around 1mm or even higher - this will move it away from your walls. Also "support distance priority" might have to be changed to "x/y overrides z" depending on your part shape.
