Posted
· Ultimaker 2+ background fan makes a lot of noise
The middle fan is responsible to cool the hotend and turns on automatically. Depending on your mainboard in the UM2, the fan starts immediately when you power on the printer or when the nozzle has a temperature higher than 40°C.
So if the fan makes too much noise, then a new one can help and I would buy an original one from an Ultimaker reseller.
If you have an older mainboard installed then the fan starts after power on and there is no workaround for that, except to change the main board to a newer version.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Smithy 1,141
