Loading Cura Profiles
Huge1
Posted · Loading Cura Profiles
Supplied files with printer SD card print perfectly. However the profile wont load into cura.
On examination of the file in Notebook the last lines of code are a random character string, as follows....
M84                         ;steppers off
G90                         ;absolute positioning
;CURA_PROFILE_STRING:eNrtWktv20YQvhJGf8QeEzRWSUqKkwg8JKmdi10YtYomvhArciRuQ3KJ3aVl2dB/78zyIUqmW6cxmpd0sMGPMzuzM988DCvlK1BhAmKRmMAdeM6Sp2loEhF9zEFrhF44CozikREyDyHnsxSCqSrB0TIVcZjaA7oKz525wDNiyLUwq2DoOgUokYFBuRnMpYJQ5CRSHZPLm5sUQi1uIBiMnEKJ3IS6AIiDsVs/GsjwDG5KBYHv9aB+0AMO....................
Is there a way to translate into something I can use?
As an aside the supplied files print perfectly, my own files created from scratch do not.
Would like to start the setting from a known position than proceed on the basis of trial and error.
For instance I found the recommended temp setting ( 200 ) did not effect good plate adhesion whereas 210 does.
In the meantime will continue looking for other files that print correctly and have profiles that will load.
