Cura 4.3 not scaling properly
V3DPrinting
Posted · Cura 4.3 not scaling properly
Hi
I have a model to scale, but not the same ratio between X / Z and Y.
X and Z should be scaled 99,6 % and Y 98,8 %.
So I have first rescale uniformly the model to 99,6 %.
82732924_Capturedcran2019-11-0916_43_42.thumb.png.70bc07766fba14456b1c5d42f3e7a3d9.png
Then unchecked the uniform scaling
157853060_Capturedcran2019-11-0916_43_53.thumb.png.4824f89b6c49073a783303136a45fc26.png
Then changed the Y ratio to 98,8 but not clicking
1856210072_Capturedcran2019-11-0916_44_08.thumb.png.28db80cddc53d609f1ca21a166b58610.png
Then after clicking, the result is
 1450235273_Capturedcran2019-11-0916_44_25.thumb.png.3a530fdacf4aab7af45f749608c95178.png
Looks like the X and Y are not properly taken into account.
I've redone the following test, starting from a full scale model, unchecking the uniform scaling
Then setting the X to 90 % and press enter. Both X and Y ratio are changed to 90%
There is a new bug in 4.3....
    28 minutes ago, peggyb said:
    did you rotate the model, something goes wrong (bug) if the model is rotated and scaled.
    Yes I did rotate the model 90° along the Z Axis in order to fit on the build plate.
    I haven't noticed the bug before, as it's pretty rare to have to rescale not uniformly a model before printing
