Okay - so I just looked at the model in tinkercad and one problem is that the white part in the image above is supposed to be above the round part.
I suspect tinkercad is exporting it where it touches z=0 which is bad - you want the second part to be up in the air. You could move it up manually (menu item: preferences -> configure cura. Then uncheck "ensure models are kept apart" and uncheck "automatically drop models to build plate".
And NEVER PRINT anything without checking PREVIEW mode first. That would have shown you that it wasn't going to print right.
gr5 1,968
There are 2 obvious possibliities:
1) Something wrong with model.
2) Something wrong with printer (underextruded).
Because this is a dual color print I suspect #1. What does your part look like in PREVIEW mode?
